Oxidation(?) inside a 42 handle?
I noticed my brand new 42 has a little bit of something that looks like dried sugar on the bottom-inside (where the blade is when closed) of one of the handles. It looks a little like the result of oxidation, but I'm thinking it's probably a production error. Anyone else see this? Thanks!
Titanium Oxide is a dull white powder that resembles talcum powder or powdered sugar. But, it does not readily form on solid Ti. I suspect it's some other kind of residue from some cleaning process.
Chuck
Balisongs -- because it don't mean a thing if it ain't got that swing!
http://www.balisongcollector.com
Hey I sold you that BM42!!! Hi Matt, its me from the knife shop last night. I am sorry that I did not notice this oxidation for you on the 42. Unfortunately its the only one that we have. I have seen other 42's with a little white oxidation, (up at RMKC) Hopefully you can easily fix it.
Also I sent you an email.
Sorry about the 42 -- I fell like I should have noticed it, have fun flipping!!!
Maybe I will see you tonight,
mmtmatrix
It's no big deal. I was just wondering what it was. Any suggestions as to how I can clean it? It seems to be pretty solid stuff. Would WD-40 do the trick? Thanks!
I suspect that Chuck is correct.
However, the 42 handles are cast so I wonder if this would allow some oxidation to form.
[This message has been edited by RKnight (edited 04-25-2001).]
Ahhh, I love RMKC!!! I picked up "BALISONG: THE LETHAL ART OF FILIPINO KNIFE FIGHTING" from them just about a month or two ago.
Cameron
"And shepards we shall be, for thee my Lord for thee, power hath descended forth from thy hand, that our feet may swiftly carry out thy command, so we shall flow a river forth to thee, and teeming with souls shall it ever be, En Nomine Patris, et Filii, et Spiritus Sancti"
A few of my balisongs
My Photopoint album
If you're having trouble getting it off, then it's not Titanium Oxide which a very soft material and crumbles at the slightest touch (which is why it's almost always seen as a powder). It's interesting how Titanium can be one of the strongest materials and its oxide can be one of the weakest.
Some metals oxidize very quickly. Aluminum is the fastest. You have probably never seen a piece of Aluminum that wasn't covered with rust. But, Aluminum Oxide, also known as saphire, is very hard and very clear. So, as soon as it hits air, a sheet of Aluminum covers instantly with rust. But, because that rust is clear, you don't see it. And, because it is so hard and has such a tight crystal structure, it seals the Aluminum. As soon as a layer only a few molecules thick forms, the Aluminum is essentially sealed in an airtight saphire case and, since no air can get in, the oxidation stops. So, the rusting of Aluminum is self-limiting. So, it's not true that Aluminum does not rust. But, Aluminum rust happens virtually instantly and is then self-limiting. So, while Iron Oxide, the familiar red rust of steel and iron metals, destroys the metal, Aluminum rust protects and preserves the metal.
Anyway, as much as Aluminum rusts almost instantly when exposed to any oxygen, Titanium rusts, oxidizes, very slowly and only under specific conditions, most notably very high temperatures. So, it's unlikely that what you're seeing is Titanium Oxide. It's probably some residue left from some solvent used to clean the casting. I'd try WD-40.
Chuck
