- Jan 22, 2011
took my bushcrafter camping last weekend and had a bit of moisture on the blade. There are a couple of rusty spots on the blade. What is a good way to remove these?
First, cut stuff with the knife and see if that cleans it up enough for your tastes. Fuzz sticks are good about this. If that doesn't work, carefully use scotchbrite pads and WD40 to remove the spots. Do this carefully working only the bevels and only in the direction of the scratches.
Renwax has a mild solvent in it that evaporates. Washing the blade with soap and water and a non-abrasive sponge, followed by drying and wipe down with isopropyl alcohol, followed by application of the renaissance wax as a protectant, may serve both purposes in terms of intervention and future prevention. If you do use a polish, take care to avoid the 3D spalting on the flats or you may remove them by accident.
Buy a metal cleaning & polishing paste named "Happich Simichrome Polish" A.G. Russell sells & recommends it for knife cleaning and it's gentle enough to use on sterling silver as James Avery Jewelers recommends and sells it as well.
This stuff is amazing and can get rid of years worth of patina in just a couple of applications. It also leaves a protective layer on it similar to Renwax
Touched the blade with a scotch brite pad. BIG mistake.
I've never tried that on knives because the gun parts turn out so slick and mirror shined.Warrior108 you and I think alike. I use Happich on my knives, gun triggers & jeweled bolts and I even use it freshen up my dive watches. If only Happich could clean up our Presidential candidates
