- Jul 3, 2016
First off I really like this knife. For a boating/fishing knife I think you would be hard pressed to better the Pacific Salt. The Pac Salt is replacing my previous hard use boat knife a Cold Steel Vaquero which even with maintenance corroded so badly in the back lock mechanism that I no longer trust the locking mechanism. To be fair the Vaquero lasted 7 years before crapping out; not too bad for a budget knife but it was heavy and somewhat unwieldy for my tastes. The Pac Salt fits me like a glove.
Lot's of Pros:
- It's so lightweight I forget I have it in my pocket.
- Perfect size for my uses of cutting lines, bait & quickly dispatching argumentative boated fish.
- I've soaked this thing with sweat & salt water and not a hint of any corrosion at this point.
- The textured FRN handle is durable , easy to clean and for me provides enough grip even with wet hands.
- The one handed opening via the Spyder Hole provides for quick and effortless 1 handed opening to cut heavy leaders to release toothy critters where the hook is not accessible for release. Makes life a whole lot easier.
The back lock is growing on me. I wasn't crazy about it at first after having been spoiled by the PM2 compression lock but the more I use it the better I am liking that back lock. It is a very secure locking mechanism and provides confidence when using the knife for aggressive cutting.
For maintenance after a hard days use on the water I flush it out with fresh water, dry and blow out any remaining water with my air compressor. I also give it a little lube in the pivot with Tuff Glide.
Now for the sharpening question:
I find I can get about 2 days of heavy use cutting bait as long as I avoid any bone. Can get a nice sharp edge with about 20 passes on each blade side with my SharpMaker. Had to cut through some bluefish bone yesterday while chunking bait and it dulled the knife a bit. I have a SharpMaker which I am learning to use. Per the instructions it states to use the corners of the white stones only set at 40 degrees for the serrated edge. After 50 passes I have the blade where it is just starting to be able to cut copy paper again without shredding/tearing the paper.
Should I just continue with the white stones using the corner only until I can bring back that edge or is there an easier/better alternative method? Kind of new to the sharpening thing so I could use some help. Thanks. Bob
Lot's of Pros:
