Is it safe to buy a pacific salt from amazon or ebay and it will comes with torx screw, or the older model are still in circulation?![]()
You could still get either one. If you're buying on eBay you could always use the "Ask the seller a question" function. From Amazon, just because Admar got a new one does not necessarily mean you will. I might depend on who fulfilled his order, Amazon or a vendor, and whether you order from the same source. Even then, not all vendors practice FIFO religiously, so you might still get older stock.
Sounds like you'd be safe purchasing/bidding on that one.This is the question I ask at eBay.
Is this the newer model with the torx bit screw that hold the handle together or the older style with the rivet stud that you cannot take it apart for service?
Also in the knife closing position, and the blade is not center in the handle, do you allow return and exchange?
And this the answer
This is the current model year - thanks for your interest!
And if the item is defective, it is covered under Spyderco's warranty for repair or replacement - or you may return it to us for a full refund.
