- Jan 27, 2008
Several years ago I did a photo tutorial of how I carve canoe paddles. I thought this might be appropriate for this forum.
First, the tools of the trade:
I use a powerful jigsaw to cut paddle blanks as I have more control and there is less blade-wander then with a band-saw.
Microplane rasps, steel rasps, files, 4-in-1's, block planes (standard and low-angle):
I use the Microplane half-round rasp secured in handmade "grips" using wingnuts.
Bench chisels and a V-gouge.
C-clamps and protective wood blocks:
Sanding blocks and contour sanding "sponges":
Diamond stone, 800 and 400 grit waterstones
Honing guides
Scary sharp!! 8|
Lay out the templates and snap a ckalk line to make centerlines:
Outlines traces and ready to cut. Yes, I know the paddle-shaft on the left is off-center. This was corrected:
Paddle 'blanks" cut, blades:
Grips:
Mark centerline:
Centerline marked, ready to remove stock from blade:
Stock removed from blades using a power planer:
Paddle securely clamped to workbench with blade fully accessable. Note: be sure to use a protective piece of wood between clamp and paddle:
Now move on to a block plane and spoke shave to remove remainder of stock from blade. Note: I make sure to stay 1/8 inch away from centerline until final shaping is done:
Major stock removed, now use rasp to shape shoulders of the blade:
Shoulders shaped, now ready for final shaping with fine rasps and files:
Now, move on to the grip. I use the Microplane rasp to create a divot on either end of the "lower grip" to allow the spoke shave to "bite" the wood. Remove stock to within 1/8 inch of either side of the centerline. Work carefully until this surface is level, flat and smooth.
Alternatively, I often extend the shaft into the lower grip using a bench chisel to remove stock. This is done on both sides:
Sometimes I get a bit fancy!!
This will be cleaned up considerably.
to be continued......
Honing guides
Scary sharp!! 8|
Grips:
Mark centerline:
