- Oct 25, 2004
This BGRS is a wood handled (don't know what kind) villager that I picked up at the MWKK '05. Bura made it. Besides the usual jazz about what a handy size and shape the 15" BGRS is, this one's got a magic edge* and was firmly locked as My Favorite Khukuri until that goldurned FF came along.
* For our new arrivals, what I mean by "magic edge" is not that the edge is glowing with magical energy or anything like that; I'm commenting on just how great of an edge it has. Unless I've done something stupid, like chopping rocks or chainlink fences (and sometimes even then), I can chop wood and brush literally all morning, give the edge a few swipes with the chakmak, and it will literally shave hair again...maybe not hair-popping sharp, but definitely hair-shaving sharp. This is not soft clear wood that we're talking about, either; these are fallen trees that have been dead for years and I don't normally avoid knots. Out of my twenty-something-odd khuks and swords, this is the only one to date with a magic edge. (I have to admit, though, that some of the others are improving with repeated sharpenings and may just get there. The BGRS was magic after the first sharpening and has remained so.)
I'm sure that there's a logical explaination for this - grinding through the decarburized outer shell, subtlely reprofiling the edge, work hardening the edge with the chakmak, etc...but there's a certain magic involved all the same. Hence, magic edge.
Dan asked and I shall obey. I broke out the PCB etchant and had at it. My normal procedure is to degrease the blade by washing it with Windex, then engine degreaser, then some denatured alcohol on top of that; afterwards, it gets a long rinse in the hottest water that my tap can produce. When it's good and hot it goes into the etchant. After thirty seconds or so, when everything is good and dark, I rinse, neutralize with Windex, rinse again, and polish. After polishing I repeat the process. Typically I see acceptable results on the first cycle, with three cycles being preferred.
The BGRS didn't want to etch. I had that sucker in the etchant for over three minutes with minimal results the first time. Polishing didn't bring much out. The second etch went only a bit better. After polishing with Never Dull I switched to Mother's and saw an improvement. The third etch did the trick, although I'm half tempted to go another three just to see what happens. I noticed that even a light polishing removed quite a bit of detail so I took a set of pictures after the third etch, but before polishing, and another set of pictures aftwards.
And it took quite a bit of polishing to remove those oxides once I finally got them to form, might I add. The surface of the blade is noticably smoother and wonderful patina (including the "blood patina") is now gone. Sounds like a good excuse to take it out in the woods and put it back on.
Photo note: each pic got two clicks of "Sharpen" in Irfanview to bring out the detail, something that I normally don't do. I was pushing my camera's limits with regards to focal distance and there was a bit of blur...not that my pics are all that good in the first place.
So while I have technically edited them, I didn't actually add anything and the sharpened images are very close to how it appears in person.
Here we go. After the third etch, but before polishing:
After final polish:
That's what a magic edge looks like. Although the hardened zone extends right to the tip, I'd reckon that the tip is a bit softer than the sweet spot. The tip will roll with effort; the sweet spot doesn't seem to do much of anything. I suppose that the edge may be thinner up there but it doesn't look like it to me.
Note the varying lines in the hardened zone. I recall a thread about this (KM?) recently. I don't know what it means but it looks kind of cool and I have no doubts about the edge's performance.
The blade didn't pick up any flash rust between the final hot water rinse and the polish - a first. (Also note that while it developed a patina, it took a long time to do so and it never really rusted.) The hamon is also unusual, although I've seen a few other unusual hamons from Bura...just not like this one. This isn't the first villager that I've etched but I've only done a few so I'm still not sure what to expect.
But, if I had to guess? I'd bet that this steel is different from what's normally used. Someone else may know more.
Dan, if you're interested in doing some nondestructive testing, shoot me an email and we'll work something out. The Camp's more or less decommed, camping season's just about over and I have a Foxy Folly hanging on the nail beside the BGRS...I could live without it for a few weeks if need be. Your comments have me curious now.
After final polish:
