Gary W. Graley
“Imagination is more important than knowledge"
- Mar 2, 1999
Some kydex sheaths are sandwiched together, pancake style, but that doesn't allow to make a thumb break section like you can get on a taco style sheath. So this one I got in today was a sandwich one and the knife had excellent retention, which did make it harder to draw the knife. I would much rather it be tight than loose for sure! So I looked the sheath over a bit and saw the area just after the one rivet and thought if I drilled a small hole there, I could tie a diamond paracord knot tightly and that would serve as a place to press against with my thumb as I draw the knife. And it works well, you do need to get that knot down tight so it doesn't wobble hardly at all, so some time with the pliers to draw it up tightly is required.
Hole drilled out
Untitled by GaryWGraley, on Flickr
Knot tied on tightly, this was 700 lb paracord so that made a good size knot
And that does help in aiding me to draw the knife without much fuss
G2
Hole drilled out
Untitled by GaryWGraley, on FlickrKnot tied on tightly, this was 700 lb paracord so that made a good size knot
Untitled by GaryWGraley, on FlickrAnd that does help in aiding me to draw the knife without much fuss
G2
