Pants for custom blades
Here are some sheaths for Joesouth and his great knives :D
one more yet...
Well done! :D Though the contrast with the belt loop is a little shocking.
Thanks for the compliment. :)
I've had a problem with dye rubbing off from the flesh side, so I nixed it until I get it figured out.
Your not alone in this problem, dye transfer has been a thorn in many a leatherbenders side. I'm not sure if anyone has cured it entirely.
But, solid work none the less! :D
I rarely use dye at all for any one of the numerous neagtive reasons posted here and on other forums, but be it flesh side or grain side you must allow the dye time enough to level out and dry completely ( depending on humidity conditions this could take up to 24 hours) Then buff with a paper towel several times until the residue coming off is practically none, and then apply Feibing's TanKote to seal. This is about a 99% cure for dyes rubbing off after the treatment. Most people, myself included, tend to rush and try to finish before the dye is bone dry.
Paul
