Thank you for your help guys.
Bufford, I've had the shredder for maybe 4 years and don't use it that often (I need to empty the bin about every month) and understand taht purchasing a new shredder is an option but I thought that I would try and see if their is anything that I could do, before I buy a new one.
And Bufford, I tried you suggestion to check the "safety interlock between the collection container and the head of the shedder " and ran into a problem. I disassemble, the unit that is I tried to open the "head" of the shredder and removed 6 screws on the bottom of the shredder head (i.e. the part that you can not see when the shredder head is placed over the paper collection bin) so that I could open the shredder head and get a peek inside but the bottom part doesn't separate from the top and I don't want to force it (and possibly break/crack the plastic).
BTW, apparently Techko Inc makes the shredder for Staples and the Model number of the unit is SH1524CP.
In any event, I would appreciate a little more help since the shredder head and collection bin appear to be lined up properly, the unit has an amble indicator light that lights up when it's not aligned and a green indicator light when it is aligned properly.
I tried removing any loose paper that I a, able see with an eye tweezer but obviously can do a better job of cleaning it out if I was able to dissemble (take the bottom part off the shredder head) and any help would be appreciated.
Thank you again for your help guys
Bob
