- Oct 20, 2004
I have had the paper wheel system for over a year now and can use them to get knives very sharp in just a few minutes. I usually just use them to touch up my EDC blades maybe once a week. I normally just use the slotted polishing wheel unless the blade has gotten very dull when I will use the grit wheel which is not often.
I just got another Benchmade Rift as a backup to my EDC user (a year old Rift) which I really do carry every day. In comparing them I noticed quite a bit of the blade has been worn off at the edge! I have been sharpening this knife for a year but this is a big concern.
I also looked at my Kershaw RAM which is only a couple months old and carried in conjunction with my Rift frequently. Looking at it I also noticed quite a bit of metal is missing at the plunge line of the blade.
I do not shapren these knives all that often and would not expect this kind of metal removal when just using the polishing wheel.
I am now at a loss as what to do. The wheels are very handy and get my knives sharper than I have ever been able to get them in a quick amount of time. However, if I am removing a substantial amount of the blade just keeping the blade sharp then they are not going to last as long as these newer knives should last with the newer materials they use.
So now I don't know if I should start looking for a different sharpening system? I have wanted an edge pro for awhile but it might remove just as much material? Maybe I need to get a strop and learn to touch up the blade on it? I did make one but have not had any luck with it. In fact, I might even make knives duller with it.
So does anyone have any thoughts, recommendations, critisims, etc?
I will get out my camera and see what luck I have with the macro setting capturing the blades where the metal loss has occured.
Thanks!!!
Ryan
Thanks!!!
Ryan
