tightening down the pivot shouldnt do anything, if the bushing system is working correctly.
the whole point of the bushing system is that you can tighten the pivot as far as it can go but still retain smoothness. the same mechanism is used the CRK sebenza.
Err... the bushing is there to make sure that the blade still move regardless of the screw tightness. If the pivot screw is too loose, it won't magically keep the blade from having side to side play.
yes the bushing is there to keep consistent smoothness. but assuming the knife is put together correctly there shouldnt be any play. if the OP had loosened the screw to the point of it almost coming out then there would be play.
i'm confused now too. I think we need some diagrams. Is the "bushing system" on the para 2 different than other knives? If I have side to side blade play on my knives I tighten the pivot and the play goes away. Why will that not happen with the para2?
mine has some left/right blade play but only if i hold the blade near the tip and give it a good wiggle. holding it closer to the pivot there's none so it might just be flex. nothing that concerns me at all
