Guys I need help from the experts. I have a para 3 prob 2 months old. It had slight play side to side when new. I have read that this normal for the compression lock to have slight play. Others claim theirs have none. The play can't be felt when holding the blade close to the pivot and also zero vertical play.
When I disassemble and re-assemble it has no play for about a day or 2 and then back to square one with slight play. I have never had a knife that is as complicated as this one. I am OCD and hate blade play, but if this is normal for the para 3 then maybe I can learn to live with it. What irritates me is the fact that it develops play after a while. I have used loctite, but does not help. Even when tightening the pivot without drop shut it still develops play after a while. I am so used to knives (example ZT0550) you tighten the pivot till the desired tightness and loctite and thats it.
I don't feel that it's a lemon. The fit and finish is perfect, lockup perfect, centering perfect everything perfect other than the fact that it always develops side to side play. I have probably disassembled and re-assembled 15 times but happens every time.
Any tips will be greatly appreciated. The other weird thing is that when the blade is halfway open there is no play up until the point just before the lockbar engages then you can feel blade play.
