- Jan 9, 2022
I asked this in another thread but I decided to just create a new one since the one I posted in was a few years old, but this is what I had asked:
I'm having the same issue. My dlc Para 3 is tightened all the way. It drop shuts and tiny bit of blade play. All my other Para 3s you tightened it the blade gets stiff doesnt open or close without using your other hand or really flicking your wrist or if you loosen the pivot a bit. So like normal. But this Para 3 idk what's happening. It doesn't get tighter. All the way tightened it still drop shuts without any movement and there is some play when blade is open. Knife is brand new and stamp on the blade says 23 and washers all are still in new condition. I looked at the pivot set up and its the same as my other Para 3s that do tightened. Looks like a barrel pivot. I think barrel pivot is the correct term. My Sage 5 doesn't really get AS tight but I know that's due to having an actual bushing system but why does this happen with my Para 3? As far as I know, this Para 3 is the same as my other Para 3s yet my others ones do tighten like normal. Any help would be appreciated. I'm not really bothered by this but I'm just confused as to why its happening.
Edit: I do think something is going on bc no matter what I do blade doesn't center. I've taken it apart and put it back so maybe it's related?
