- Oct 8, 2021
How do you fix constant off centering on a para 3? I took it apart the acid etch the blade and had it centered but after a week of use and carry is tiled to one side more now and it keeps moving.
G-10Is it the G10 model or the lightweight?
I’m gonna take it back apart tonight and clean it and see if that fixes it. It’s had a lot of dirt and grime pass through it at work since I’ve got it so maybe it’s just dirty. If that doesn’t fix it I’ll post some pics.Odd. I know they had issues with the LW models. If you can upload a picture or two. Now I remember when I broke mine down I actually put one of the washers in wrong and it kept the scales from seating correctly.
….and a 24 hour cure time.Sometimes you can tinker with it and get is straightened out. If it was centered and is now off, your pivot screw probably walked a little. Hence reference to checking screws and blue loctite.
H Haun122493I’m gonna take it back apart tonight and clean it and see if that fixes it. It’s had a lot of dirt and grime pass through it at work since I’ve got it so maybe it’s just dirty. If that doesn’t fix it I’ll post some pics.
www.bladeforums.com
