I will explain it is car terms.
A Corvette will go from 0 to 60 in a 5 seconds. It will reach 100mph in about twice that time.
A Chevette will go from 0 to 60mph 8 or 9 seconds. But, it won't reach 100mph for 40 or 50 seconds.
This is because the corvette is at 60% max speed at 100. The Chevette is right at 100% max speed at 100 - if it hits it at all.
Your oven is rated at 2000° max. Rated doesn't really mean it gets there easily ... or at all.
1950° is 97.5% of max - if your oven will even hit 2000°. I suspect that other factors are also hindering the max temperature (see below).
It will take your oven a very long time to heat to 1950°. Rebound will be long, too.
Things that will make a difference are:
Line voltage - the oven is rated on 240V. if your line voltage is 220V ( very common), you will only get 91.6% of the max temp.
Line wire gauge - for the voltage to be delivered for hours, you want 10 gauge wire. Even though the oven only draws 7.5 amps per leg, that still will require a sufficient size wire to prevent heating the wire and poweer loss.
Line length (voltage drop) - the farther from the power panel the oven is, the lower the final voltage.
