The Fusion Steel Heart, FSH, and the Heavy Heart Fusion Steel Heart, HHFSH both have 8" blades. The difference between the two is that the FSH has a blade with a full-height grind and thickness of 0.25" while the HHFSH is saber ground with a blade thickness of 0.27".
Thanks for the correction SD33, but I was under the impression that FSH's were full flat ground. Maybe I'm confusing myself with full-height grind and full flat ground.
the original FSH had a convex grind
We change the parameters daily,, here on the compound,,
And that FNMOASH is something like 1 of 14 that were made.
Based off the MOASH which is a whopping .345" thick.
ya but that's a deceiving number. since the entire blade is double edged the majority of the weight is removed from the front end, so it comes out neutral to handle heavy. plus the taper that starts at the belly which removes even more weight from the front.
I found it very weird in the hand, a giant massively thick handle with almost no blade heaviness. it didn't really fit into my idea of a fighter (I'd prefer blade heavy for that, and a thinner top edge) or utility chopper...
if nothing else it was pretty.
