- Aug 7, 2014
I just got my second Paramilitary 2 yesterday in the mail, digicam scales with a black DLC blade. My first has black scales and a satin blade, and the new knife is much harder to open. When I first got it, I couldn't even flick it open at all. It would stop about 2/3 of the way even with the hardest flick. Now I've probably opened it at least 1000 times, and it's gotten much better, but it's still alot stiffer than my satin Para2; it takes more effort to open and won't close with gravity alone. I realize it will probably continue to get smoother with time, but I don't remember my satin Para2 ever being quite so stiff.
Also the compression lock on the new knife isn't smooth. When I flick it open with authority, the compression lock takes probably 3 or 4 times as many pounds of force to open than my satin Para2, and will open abruptly, like the liner is caught on the tang of the blade. When I open it more slowly, the lock takes a little less force to open (still noticeably more than my other Para2) and has a little gritty/grainy feel to it. I have yet to take it apart, but from the back of the knife, the tang doesn't look any different from my satin Para2 (besides color of course)
I may just be paranoid, or it may work itself out within a week or two, but I was just wondering if anyone else has had either of these issues (especially the second one), with a Para2 or any compression lock Spyderco or any ideas on what it could be/how to fix it.
Update: I just got done putting it back together. There was a bit of loctite on one of the washers (washer was stuck to the frame and there was powdered loctite between the washer and the blade). I also washed the blade, wiped everything down and put a drop of dri-lube on it. One of the scale screws close to the pivot screw was overly tight also, enough so that it was causing extra pressure on the frame at the pivot screw. Everything is much better now. Still not quite as smooth as my other Para, but now it feels like another quality Spyderco
