I've always liked the looks of Spydercos, but have usually had issues with blade-play with their lockbacks. So, I've preferred liner-locks, as they don't offer much blade-play. I was honestly quite fed up with my lockbacks, which where all Spydies. But, then I read about the Para 2 and thought -- OK, I'll give their folders a last try. I thought, a combined liner-lock and lockback with Spyderco looks. I had to try it.
The Para 2 compression lock delivers well and beyond. There is zero blade-play up and down and if the blade wiggles sideways you can just tighten the screws. It feels like a fixed blade while in use, but I cut myself really bad while opening it quickly once, so I'll never do that again. It's like as if there are different levels of resistance in the opening arch, but it could just be my knife (even with different torque on the screws). The compression lock is so tight that I feel as if I'm gonna wear it down just by releasing the blade from the locked position. A lot of people say you can't use it as a lefty, but I can open and close it very well with my left hand and I'm primarily right-handed (like 25% ambidextrous).
The Para 2 is by far the best folder I have ever owned, but I am also very cautious when using it. That forward-dropped blade is not good if you slip with your grip onto the blade while sticking something, because the blade/edge-line almost reaches my knuckles past the grip-line. It's like a giljotine. The tip is also very pointy, so it's easy to stick yourself with it. The ergonomics are great, but not as a bushcraft knife (which it isn't). It's more of an EDC-urban-environment type of knife (to me). The grip is great for urban cutting tasks, but not the best for carving wood, although it works fine for that too (just not optimally).
