- Jun 6, 2014
I have a very lightly used PM2 that had no blade play when new but the other day after a little use I noticed some side to side that could be felt. Went to tighten it up a little and all the screws were already pretty tight but I tightened the pivot, lockbar, then handle screw a tad more in that order one at a time then checking after each adjustment without any change with each screw. The blade can also swing back and forth freely when the lockback is out of the way even with the screws all the way tight, like the width of the lockbar or standoffs requires thicker pivot washers to even allow me the possibility of overtightening the pivot? Or do I need to loosen all the screws and retighten them in a certain order? I have no issues with any of my liner locks but don't know if I am overlooking if compression locks require different adjustments?
