- Jul 17, 2019
I just started parkerizing knives and I've got a couple questions:
How do you put your mark on them? I tried electrochem etching before sand-blasting but the blasting pretty much wiped the mark out. I'm concerned that if I try to mark it after I sandblast it though I'll get crud on the blade which will interfere with the parkerizing.
How does parkerizing damascus work? I know parkerizing works best on a relatively low-grit finish (120-160 or so), but I usually polish damascus to a super high finish. Do you etch for depth, sand-blast, parkerize, then hand-sand the highs to a bright finish? I feel like that would remove a lot of the topography, but I could be wrong.
Any insight would be appreciated!
