Ladies and gentlemen, children of all ages, today i present to thee, the patina tutorial for knives that are stubborn to patinize.
Materials:
CLR (comes in grey/silver jug, available at hardware stores)
A glass, container, just, jar , whatever.
Paper towel, few sheets
your knife
and a small test tube, beaker or pouring container
Procedure:
Ok, first lets do your setup.
1.take your knife, and find what blade you want to patinize ( if this isnt a word, lets assume it is)
2.lay it on the large container cutting edge up.
3.next, take some paper towel and cut it the same length as the blade, if it is longer thats ok, but you dont want to waste paper towel.
4.Next lay it over the blade so that it folds and covers both sides.
5.After thats done, pour some clr in the small container,
6.after that, pour small amounts of clr onto the paper towelled blade, remember it does not take much clr to water down the paper towel.
7. Make sure that there are as little air bubbles on the blade as possible, you cant really eliminate them all (gas is created in the process) but its better to have less air bubbles in the paper towel.
8. Let the blade sit with the paper towel for a while (half an hour, or more) if you want a real deep patina let it dry, and resoak the towel (this will take a while).
What is happening: The CLR corrodes, and induces oxidization, but the clr is not in such a great quantity that it removes oxygen which is needwed to oxidize.
9. After your done, remove the paper towel and look at the blade (kinda ugly )
10. Wet a piece of toilet paper, or a qtip and rub the blaee, this will get rid of any residue that stays on the blade.
Thats it folks, you should be set with a nice patina that will protect your knife.
now for some pics
Pic links dont work anymore, someone email me and ill send them to yuo.....and hopefuilly you can post them on bfc
Materials:
your knife
Procedure:
now for some pics
