How many of you use it, and if you do, what are your opinions of it? I tried it today for the first time, and found it to be the greatest stuff since sliced bread. I coated a 1/16th thick blade of 01, soaked it at 1500o for a bit over five minutes in an evenheat oven, and had no carbon loss that I could detect. I programed it to soak ten minutes at 1250o, and then come up to full heat for the soak. I quenched in motor oil thinned with deisel, heated to 125o. Yeah, I know, I gotta get a better quench oil, but it came out with an even hardness that a file won't touch. I did not soak longer due to the blade being so thin. I then boiled the blade in water, and it came out gray, but perfectly clean. I am impressed.
