I routinely peen the pins in my Buck 110s, which are also monsters. I taped a small, thin, washer with a hole just slightly larger than the pins to my finish anvil.
I set the pin into that washer and tap away, very gently, with a fairly heavy hammer [20 ounce]. Be really careful to use about a half dozen light blows and do NOT hit hard enough to bend the pin or it will ruin your piece by tearing up the holes.
The washer allows a tiny bit of room for the pin to expand and tighten up.
Then turn it over and repeat, again with the washer.
Once both sides are done with the washer, you can just move it off the washer and peen directly on the smooth anvil. I keep my anvil heavily waxed and polished to allow the peened material to expand as much as possible.
Again, many small blows.
This takes very little time and gives me great results.
Please let us know how these suggestions work for you. Good Luck!
WinDancer@OlyWa.net
Large selection of Buck 110s for sale
www.olywa.net/windancer/webknives.htm
[This message has been edited by WinDancer (edited 21 September 1999).]
