while peening my first set of 3/8" SS bolsters (similar happened to my first set of brass but not as bad)i found it difficult to get both completely seated on all four sides. I do admit the the two pins were more towards the front then the back but were spaced well top to bottom... i am using 1/8" pins and a 3 lbs hammer and anvil, leaving almost a 1/8" of pin on both sides before starting. i then evenly hit all both pins on both sides until the gaps close and then focus on the pins that are near any remaining gaps. It seemed like it got to a certain point and the pins swelled between the tang and bolster making it very hard to get both bolsters seated. there was about a .001 inch gap on one side and when i got that side seated the gap moved to the other bolster... is there any suggestions to improve my results??
thanks
thanks
