Pen blade slightly loose?
I just bought a Buck Canoe with bone handle, the main blade is tight but the pen blade has slight movement. Is this ok or should I send it in to get fixed? I got it on sale at Walmart.com for $11 so sending it in would cost about half what the knife did. If a slight movement is ok then I can live with it but if they all should be completely tight then I may take it back to my local store for refund and reorder online as the knives are $23 in store. The liners are all smooth with no gaps, also if I grab it with my fingers at the knife frame then it won't seem to move but if I grab it with my fingers at the tip then there is slight movement. thanks for any help.
You seem happy with the fit and finish otherwise. If the knife cuts safely and properly, I would consider keeping it.
Yes the fit and finish is just about perfect and the best I have seen on a China knife, the blade is only slightly with play.
What I’ve done in the past is put the bolster in between a phone book or something thickly padded and give it a light hit with a sledge or other appropriate hammer. Check the blade play and go again if you need to. It’s easier to tighten a knife than loosen it, so go slow and you’ll be happy.
Thanks everyone, after cleaning and oiling I decided to use as is. Just too afraid to whack it and it really isn't that bad but first regular pocket knife I have had in years as I normally buy one bladed liner locks. I decided while they were on sale to get two more Canoe's, they both were finished beautifully with no gaps, blades tight and snappy. The only thing if I could say was wrong was the bone handle scales were sticking past the bolsters just a tiny bit but nothing too bad and overall I would say they were excellent. The first one with only slight blade movement on the pen blade has it's bone handle scales smooth with the bolsters. I am for sure gonna buy more traditional pocket knives, Buck is the brand I know best, is there other brands that give you a good knife for the money? Thanks again.
No need to hit the knife.
Put a few layers of newspaper around it, place it in a vice, and slowly tighten. Don't overdo it, and check it after each little bit of turning.
I have had good success doing this on several slipjoints.
Case make a wide variety of slipjoints, but they sorta vary in fit and finish. Sometimes they come perfect, sometimes you have to tighten pivots or re-glue shields.
