Thanks for al the advice guys, you have been really helpfull.
I shall share my experience with the knife so far and until I get it sharpened and add my own review to it after testing.
SO far I have spent around three hours with 400 grit paper it doesn't do much very quickly does it, I noticed when looking from choil section to tip that the straightness of the edge is a little off so I am going to try and fix that during the sharpening process.
I tried my coarsest file on it and it felt like I was filing another file, it barely bit at all, then I moved to my cheap but working diamond 300 stone, it worked a little better so I now have the edge on one side almost even, I have decided to go for a convex sabre grind with a little help from stones.
I have been using my fingers to try and get the right edge, I am not sure yet if it is a mistake as the fingers would tend to push the paper a little further over the edge and add 10-20 degrees to it but it seems fine so far.
I tried it on the leg as previously recommended by a few ppl, I tried it on a soft surface and thought it was too damn slow.
It is not an even convex but for my first attempt at sharpening this style of blade I do not think it is too bad.
I have however put a few scratches on the side of the blade which is not straight anyway, so I might get both sides to a 400 grit finish and sharp and then run over the side of the blade with a metal hungry stone and try and level it out a bit, then work from 400-600-800-1000-1200 and 2000 grit papers and then finally apply a hand rouge to buf it up.
As for loving the khukri I think I always did ,I have a few cheapies but never had one of this quality, I am very pleased to own it so far.
It fits nicely in my hand I don't think the middle grove will prove a problem with my hands, it feels quite light and fast in the hand but I am sure she chops up stuff quite nicely.
ANother question for you, is she supposed to have a hamon, I am not sure I have read any where that it is differentially heat treated, But if she is I would like to try and bring it out in her too, I love to have the hamon showing, even though it might take me till two weeks time to finish the sharpening alone.
I am going to have to use militec tonight cause I don't know where my tuff glide is, but I am also going to try and get better oil at the weekend. It should keep her until then right?
The smal blade does seem to be very small less than 2 1/4 inches I think.
The small blade does seem a little soft, even my mini arkansas which is not that aggressive a stone brings up a super heavy bur in seconds.
I love the bone handles they are a work of art with quite a nice grain structure, Thought is is quite hard to see because of the many fine scratches, any one know the best way to polish bone?
I am also hoping to make my own sheath out of leather, the reason for this is that I simply want a survival kit built into the set, so if I ever have to grab and go I have a good basic kit to keep me going,
But does leather sheath's make carbon rust faster, I imagine it might cause of the condensation which may build up in hot climates.
I am too tired and couldn't be bothered to set it up now but I am going to arrange a set up and take pics every day or so so I can track my own progress and because everyone likes pics, I know I found very few good quality pics when I was looking for reviews originaly apart from the passaround thread which had some very nice ones.
How do you guys feel about file work on khukri's?
I love file work on knives in general but does it really suit the khuk?
I may also try to etch a dragon pattern into the tip of the blade once I get everything else done.
I have a lot in mind so it might take a while to complete but I am sure that it wil all be worth it.
I shall go now and get some more done on it.
