Sando
Knife Maker
- Jul 4, 2002
In the search for the ultimate slicing edge I've tried another shot at convex. Dan's video clips are quite haunting. I have to duplicate them. Here's the stats:
1/16", ATS-34, 5" long, 3/4" wide, hollow ground kitchen utility blade.
Edge was about .015" thick when I stopped grinding.
Nothing new there
Then I started on the edge using my Sando-rotary platen (to produce a slightly convex grind) and used an angle of about 15 degrees. 120 grit, 65X, 45x, 15x 5x, leather strop.
When it was done, it did OK on the horse hair brush, but a flat ground edge grabs better.
It did just fine on the wood chopping - that thin of a blade doesn't take out much wood, but point is it didn't chip or roll.
Jeans cutting was pretty amazing. Went thru an old pair of jeans like butter. I don't mean single thickness, I mean the top where the belt loops are - folded and stiched.
However, when it came time to paper slice testing
It sliced 4 sheets of newpaper like it wasn't there. Then 10 sheets, then 10 sheets folded. Still could hardly feel the blade go thru the material.
Holding an old MSC catalog (40 sheets or so) in a clamp it neaty removed a corner in a single stroke. Slicing the catalog in half from the spine it made it 3/4 of the way thru. (remember this isn't a big fighter - it's a little kitchen knife).
I'm might be slow to catch on, but these convex edges are a whole different world.
Steve
Nothing new there
Steve
