- Sep 7, 2001
The mailman arrived on Tuesday morning with a box. I knew it was the 15" Ak because I could see the chappe sticking out of it.
No damage though and it was still covered in plastic. I quickly ripped open the box and looked intently at the pages from the Washington post. For some reason I like skimming foreign newspapers. It's a treat to get the front page.
I got a Walgrens flyer from Uncle Bill once... Goobers were on sale, but I digress (digest?)
After putting down the newspapers I tried the same tests as on Pen's videos. It worked as advertised. However, I couldn't get it to push cut with the edge always perpendicular to the paper which is how I thought it was done. Not that my edges could do it either but just my perception.
General appearance.
Pen polished the horn with "Briwax" and gave the steel a satin finish. Nice shiny handles
I didn't do the karda tests like the video though. Convexing the blade took the edge back about 3/16" I would guess. This gives the overall profile of a BAS. I suppose convexing a BAS will make it look like a sirupati. Convexing a sirupati might make it look like a bent toothpick.
The fit of the sheath due to less edge was loose. It stays in place from friction at the bolster. I like this. The blade can be resheathed with little effort.
Slicing Paper
The convex edge sliced paper smoothly throughout the edge. Compared to mine, the convex edge took less effort. Not by much but it was noticeable. The convex edge wouldn't slice paper on really shallow angles though because the sides of the blade start to get in the way. Not a huge difference, maybe 5 degrees or so. Not a big deal unless you like making paper ribbons.
Mangling Cardboard
Next was to cut up the box that Pen shipped the knife in. Again Pen's AK required less effort to cut through the box.
Shaving
Since I was sitting on the floor, I took the oppurtunity to shave part of my leg. Both shaved but again the convex edge was sharper.
Enough goofy tests. The blade sharpened by Pen was sharper than the one by me. Then I cut stuff and it was good.
Brush
I found no difference in the two when cutting light brush. However, while cutting brush with thorns a longer blade would be preferable.
I was still digging stuff out of my skin this morning. There wasn't too much difference cutting limbs (wood). After a few minutes of cutting with each the convex edge still shaved as it had when it came out of the box. Mine still shaved but only after turning the skin red. I think I scraped enough skin away that the hairs just fell out.
The real difference was seen when cutting a log. The convex edge tended to push the wood outwards, breaking pieces off (wood) instead of me having to cut at the opposite angle in order to release the chips. Even with the flat grind I've never had a problem with the blade getting stuck in the wood.
Looking at the edge there is a lot more metal closer to the cutting edge than there is with my flat grind. I think this would be more evident in a larger blade where the force and torque on the blade is greater than on a 15" blade.
I haven't really had a chance to go through the video in detail yet. However, by playing with the convex edge it's something I figure worth learning how to do.
Thanks again to Pendentive for sharpening the AK and making the video.
(all spelling and grammatical errors were intentional)
:yawn:
General appearance.
Slicing Paper
Mangling Cardboard
Shaving
Brush
:yawn:
