- Aug 16, 2013
Comparison of two Kailash kukri, Pensioner and Mutiny.
Weight of the blades, both have the performance grind:
Rosewood Pensioner 585 grams
Rosewood Mutiny 514 grams
Balance point of the blades:
Tip, don’t try to balance the flat kukri on your finger. Because of the shape and weight distribution the kukri will turn edge down.
Rosewood Pensioner 8,5 cm from bolster
Rosewood Mutiny 12 cm from bolster
Pictures of the kukri
I chopped a pine beam 30 times, twice to be sure of the result.
Both cuts should have been about 8 cms wide.
Mutiny chops a bit better.
After the chops I counted the total chops the kukr needed to get to the apex of the cut.
Mutiny needed 61 and 76
Pensioner needed 82 and 83
Again the Mutiny did better
Next I did full force chop in the beam to so how deep the kukri goes and add the depths of both sides.
Mutiny got a total of 6,3 cm
Pensioner got a total of 6,1 cm
Mutiny has a slight edge on chopping.
Last I chopped a dried oak plank, each kukri 30 chops
Mutiny again did a bit better.
I think I can say that the Mutiny outchops the Pensioner on a slight margin.
