As most of you know..when a folder is in the closed position and well built, the knife has its blade dead center between liners. This is due to truely perpendicular hole drilled into tang of blade and truely flat liner sides. How come I can't get this on a daily basis? I have checked drill press table and it checks out to within a thou or so for perpendicluar to bit. I hand lap stainless liners on sandpaper on granite surface plate. I start out drilling the pivot hole with 1/16" bit and increase to 3/32" or what ever the pivot pin will be. I am at a loss as to what else I should check for. I have used bronze bearings rather than straight pivot pins. Still no better. I think its just luck if I get a good centered blade.:grumpy: Any thoughts? Thanks
