- Aug 14, 2002
Description
KS1910CKT: R.A.M. Flipper - Plain Edge $35.00 shipped!
Kershaw® Knives
When a knife is this bold, safety is a key consideration. Thats where the Hawk-Lock® on Kershaws all-black R.A.M. (Restraint Articulated Mechanism) comes in. The patent-pending Hawk-Lock keeps the R.A.M.s Tungsten DLC coated blade exactly where the knife user wants iteither securely locked inside the handle for carrying, or safely locked into position for use. The R.A.M. is equipped with the ambidextrous Flipper opening system as well as built-in thumb knobs for fast and easy opening. To close the blade, unlock the Hawk-Lock and fold the blade in. This unique technology led Blade Magazine to name the original R.A.M. as 2007s Most Innovative American Design.
Specifications
Steel......Sandvik 14C268N stainless-steel with black Tungsten DLC coating
Handle...6061-T6 anodized black aluminum with textured black G-10 overlay
Lock.......Hawk-Lock®
Blade......3-1/8 in. (7.9 cm)
Closed...4-1/4 in. (10.8 cm)
Weight...3.6 oz.
Includes removable/reversible 3 position pocket clip
Designed by Grant and Gavin Hawk
Made in the USA
Description
CR2380: RSK Mk5 $17 shipped w/ box & paper work
Columbia RiverSometimes simple is better. Here is a skeletonized fixed blade designed as a personal carry for emergency and survival use.Doug Ritter's RSK Mk5 (Ritter Survival Knife) is not a knife you would use all day for normal work tasks. But, based on Doug's philosophy that "if it isn't with you, it can't save you," it is compact and light enough to fit in almost any small personal survival kit or stash-away location, yet robust enough that it's a knife you can bet your life on.
Doug is the founder of the Equipped To Survive and an international authority on survival equipment. The RSK Mk5 is a collaborative effort based on Georgia knifemaker David White's custom Shrewd Survival Knife, itself the result of collaboration with Dr. Andrew Osbourne.
Weighing in at less than an ounce, the skeletonized fixed blade sports a 1.75" wide-chord drop-point blade with a high flat grind. The high-carbon steel blade has Doug's preferred stonewashed finish for improved corrosion resistance.
The ergonomic curved handle provides a secure and comfortable two-finger grip while a brightly colored nylon cord fob adds additional length and grip.
Use it to make fuzz sticks, construct shelter, gut a fish, dress game or for self-defense. Whether it is wilderness or urban survival, the Mk5 will do its part to keep you alive and kicking.
Includes a custom-fitted Kydex® sheath and a mint-size carrying tin along with Doug's suggestions for building up your own personal survival kit.
Specifications
Knife:
Blade: Length: 1.75" (44 mm)
Thickness: 0.12" (3.0 mm)
Steel: 3Cr13, 52-55 HRC
Knife: Overall length: 3.81" (97 mm)
Weight: 0.9 oz. (26 g)
Sheath:
Material: Kydex
Length: 2.25" (57 mm)
Width: 1.47" (37 mm)
Weight: 0.3 oz. (9 g)
Perrin Concept - Neck Bowie $85 shipped
Neck Knife
Click to enlarge Fred Perrin is well known for his unique designs for various hide-out types of tools, and probably most noted is the La Griffe neck knife and his Street Bowie.
Here we have a production model Neck Bowie made from .114" 440C Steel, with a polished finish, and flat V grind.
2-3/4" Blade
5-7/8" OAL
Comes with Kydex sheath and adjustible neck lanyard
Here are the picsThese are unused but have been lightly stropped to get a hair poppin' edge!
Kershaw® Knives
Specifications
Weight...3.6 oz.
Made in the USA
Description
Specifications
Knife:
Sheath:
Material: Kydex
Neck Knife
2-3/4" Blade
5-7/8" OAL
