I got both of these knives for christmas and wanted to give some thoughts on them. The tenacious is partially serrated and the persistence is plain edge. I haven't had a serrated spyderco since my GIN1 native that I got over 10 years ago and wanted to give it another shot.
The good:
These both lock up TIGHT. There is a great sound when they lock open and there isn't the slightest bit of blade motion in any direction. They also have a good, audible click when they close all the way. Opening and closing is really smooth.
The fit and finish is at least as good as my other spydercos. The inside of the spyder hole is sanded smooth, unlike my delica and enduras, which seem just to have the marks from the cutting laser.
There is really a lot of blade on these. Although the persistence has a shorter blade overall than my delica 4, it has a longer cutting edge, and the blade is thicker and wider (the persistence is also slightly shorter when closed). Both the persistence and the tenacious are a handful and the blades are very beefy. I really like this with the full flat grind, and makes them feel a lot like the original manix (which I never got to own). That said, these are not too heavy to carry around, due in part to the skeletonized liners.
I like the overall design of these a lot: the aesthetics are very nice, with clean lines, and the knives are very comfortable to hold in a variety of positions. The blades fit the handle very well both when open and when closed.
The bad:
I just personally don't like G10. I think it's way too grippy on my pocket, which makes it really hard to draw. I think I'll replace at least the clip side with micarta or something.
The spyder hole on the persistence is covered just a little bit by the lock and the scale on the side that I'll be opening it from (I'm left-handed). This is also an issue with my native II, so I'm used to it, but it's still a little bit of a PITA.
The clip is stiffer and tighter than on my other knives. Combined with the grippy G10, these things just don't want to let go of my pocket. I like security, but I also like to get my knife out when I want.
When closing, the ricasso doesn't extend away from the handle as much as on my other spydercos. This means that, when closing the tenacious, the blade sometimes bites the nail of my index finger (remember, I'm a lefty). This isn't a problem on the persistence.
Other thoughts:
I notice that the handle on the persistence is longer above the pivot than it is on the tenacious. I wonder why that is.
These didn't come out of the box quite as sharp as my other spydercos. This is neither a good thing nor a bad thing I don't tend to like a razor-edge on my knives anyway, and these will accept a toothier edge just fine. I have had experience with this steel on the Byrd line and I have been very happy with it.
Overall, I think these knives would be great for any type of use. I can't imagine better knives for the money.
- Chris
The good:
The bad:
Other thoughts:
- Chris
