- Jan 14, 2000
So I'm not buying many CS knives these days. I'm well supplied and I'm put off by the change of ownership and loss of Lynn and Demko.
I recently picked up the Talwar XL and the Oyabun limited. Both are nice but they both have a feature that's been commonplace on their Taiwan-made knives for many years.
Asymmetric edge angles! It drives me nuts. They are consistently off in a major way. I don't mean the width of the edge bevels. No, they take care to make those even so that at a glance they look symmetric. Trickery!
But the angle from side to side is so different that you can easily see it and feel it. Of course when you sharpen you have to make a decision whether to match the 12 degrees on one side and 20 degrees on the other side - I'm just estimating - or sharpen normally and have to remove a ton of steel from the side that was under-sharpened at that low angle. Grind, grind, grind and shrink the bevel on the steep side as you re-center the edge. Then back to the steep side to lower the angle.
Seriously, I don't understand how this factory is so consistently inconsistent! Is it one guy sharpening thousands of knives or do they train workers to suck?
Rant off. I've been around and I've never seen this at such a scale from anywhere else.
I would just add that it's not even consistent for the entire length on one side so you wouldn't be able to match the bevel even if you wanted to. But that's a more minor issue IMO.
