I ordered a Pheer a while back and it arrived yesterday. This thread will be a review with pics, which I'll add later today once I get them off the camera.
Initial thoughts:
Solid machine, it's not thin tubing and the flat stock is not light weight. I know a lot of folks were concerned that it is lightly built but I don't get that feeling at all. It's not super heavy duty construction, but I don't see where anything has the potential for unwanted flex in normal use.
The feet have sufficient spacing to be stable and have 5/16" holes that are a snug but generally smooth fit for galvanized bolts. I had to tap one through but that was due to paint in the hole. I used the same on the motor.
Excellent tracking. I used the suggestions folks on here made regarding where the tension arm should be in use (lower rather than higher) and have it positioned roughly horizontal right now. I'll fine tune but that seems to be working well.
Good tracking control. You turn the knob, it moves consistently and smoothly. It's easy to fine tune positioning of the belt.
I only got a 1hp motor due to my budget. My work style doesn't put a huge load on the motor anyway, but I was a bit concerned that I under bought. I haven't done any heavy grinding yet but it seems fine so far. I'll update this when I post pictures, after testing some more.
The paperwork for the motor was included, but Jose was thinking ahead and had the wires bundled with colored electrical tape to match the VFD's wiring. No confusion about which wires go to which, rotation issues.... Just match colors and go.
I got upgraded to aluminum wheels along with the 2" rubber contact wheel for the top of my platen, so I don't have any info on how well the poly's work.
I'm happy with it so far. My only annoyance is that there weren't any wire nuts in the package. No big deal, but it seems like a silly thing to not include when you know the person has to connect the vfd to the motor and you've already prepped and color coded all the wires for them. I had to go to the hardware store for some stuff anyway, and I imagine most folks have wire nuts that would work, but I only had large ones. I bought an assortment of smaller ones and can check what size I used if anyone cares.
Pictures will be added later, I want to go grind a bit and see how she works under pressure. If you have any specific questions you want to ask, or photo requests, post here and I'll see what I can do.
Initial thoughts:
