The Marine Corps 'Daily Dozen'.....
Alternating Toe Touches
Bends and thrusts
Trunk twisters
Crunches
Flutter kicks
Leg lifts
Side Straddle Hops (Jumping Jacks)
Mountain climbers
Push ups
Stretching Exercise - Stand up straight, cross one leg over the other at the ankle, bend down and stretch the hamstring for a count of four and then return to starting position. Half are done with left leg forward, half with right leg forward.
Cherry pickers - Legs spread, start with hands on hips. Bend down and touch the fingertips to the ground between the legs as far back as possible, raise slightly and go a little further back, repeat once more then rise back to the starting position.
Rowing exercise - Lay flat on the ground with your arms extended on the ground above your head. You bring the arms forward and lift your shoulders (sort of like doing a crunch except the arms stay straight) and at the same time lift your legs up and bring your knees towards your chest. Your arms end up parallel to the ground on the outside of your legs. Hold it for a second and then return to the starting position.
