Well I am allmost done with it except for polishing the blade and handle. I almost wish I could just finish it and then post a few pics of it, but I don't have a scanner or digital camera. So I had to bring it in to work and have a friend take a few pics. I screwed up the middle pin, next time I am using a slow setting epoxy and not a light speed epoxy
I still need to finish hand sanding the blade, the night before I took the pics I was in my garage and I could not see it very well so it is not as smooth as I though I am going to buy a lamp too
The pic showing the thin part of the handle is very rough I over looked that so I still have to smooth it out. I also need to get some 2000 grit paper to finish it up. Any helpful ideas or complaints? Any coments are welcome.
What should I use to polish it and give it that finished look? The blade and micarta, I would like to give the micarta a more finished look. There is one small crack in the handle and this is from screwing up the middle pin, because of this a few other little things are messed up on the handle. Again keep in mind I still need to do a little touch up so no "the, uh... blade has a little scratch at the bottom" stuff J/K
I am going to try and post a pic again once it is totaly polished and done, but for now I had to get some pics while I can.
The Specs are:
1084, Triple quenched and triple tempered, passed the brass rod and 2X4 test and stayed sharp
Handle is black linen micarta. (This is my first time using micarta. It was rough getting the grain to look decent. Live and learn)
3 3/4" blade
4 1/4" handle
OAL 8"
Pics: Here it is
You may have to hit refresh(F5) as soon as it starts to load.
By the way for a great web hosting company go to www.skaggsweb.com and click on services.
The Specs are:
3 3/4" blade
4 1/4" handle
OAL 8"
Pics: Here it is
