- Jun 27, 2016
Ok so I have my tempering toaster with a PID installed so I can monitor the temperature accurately. The top row in the PID displays current temp and the bottom is just a set point, idk I haven't changed it. I've read the instructions it came with multiple times as well as done some researching on here and google and can't find an answer. Can I set up the bottom row to display the highest temperature the PID has reached in say the last hour or since it has been plugged it? I'm having some discrepancies in where the toaster is set, what the PID reads, and what the temper colors show. For example. I set the toaster to 450, it normally only reaches 325-350. Ive ran it for hours while in the shop and checked it every so often and it never breaks 350 degrees. The other day I put a knife into temper, came back 2 hours later and it was a blue gray. I don't think the toaster reached 550-650 degrees but I can't know for sure, thus the pid setting could help with that.
