I had tried to order the TET612 but they sent me the new JLD612 PID.
so please help.
what I have found was this guys website and he has some crazy setup maybe this is the difference in the TET vs the JLD?
has his TET612 setup like it is on 220v, but I do not think that is right at all. but from what I have read is that the JLD612 is not the same or the guy below has went off the rails.
http://www.caffreyknives.net/salt_tanks.html
Now this is how I am setting up the JLD612 for a solenoid gas valve. should it be set like this? please any help will do.
Terminal #1: Power source + or - (white wire)
Terminal #2: Line 1 Power source + or - (Black Wire)
Terminal #3: One leg of solenoid gas valve ( it said : Relay J1: #3, #4 = normally closed,)
Terminal #4: Second leg of solenoid gas valve (mine is a normally closed solenoid gas valve )
Terminal #5: ( so I would not use this one but would have 3 and 4 ?)
Terminals #6, #7, & #8: NOT USED
For K type
Terminal #9: Positive wire of thermocouple (normally the color of the out side shielding, white/yellow/brown wire)
Terminal #10: Negative wire of thermocouple (red is Negative for Thermo wire)
link to manual below
http://www.lightobject.info/download/file.php?id=736
working on programming it now.
so please help.
For K type
