Pila GL3X with a Surfire Ultra High output MN11 Lamp Assembly
Hello,
I remember seeing someone post that they had fit a Surefire Ultra High output MN11 Lamp Assembly in a Pila flashlight but i can't find it. Has anyone made this combination work? Details please?
Also and comments on the quality of a Pila flashlight?
Thanks much
Check out Candepower Forums. Someone there might be able to help you. I can't recall having seen anything about it here.
I dont think that combo would work w/out some serious modfications.
The MN11 has no reflector attached, and there is no reflector assembly on a Pila, as the reflectors and lamps are one unit.
-dan
not familiar with that setup either, but is it possible that someone used pila batteries to drive the lamp rather than fitting lamp into a pila body? i've seen quite a few mods using pila batteries to drive surefire lamps.
Pete
