- Jun 17, 2006
So I have three of these: a PE, a SE and the CF S90V version. THe CF is much lighter, partially owing to the skeletonized frame. I decided I would skeletonize my serrated G-10 model to get some of the same benefit. I disassembled it and drilled the liners: see below
Great so far, but when I was putting it back together I must have canted the thong hole tube and shaved off a little of the G-10 because now the end of the knife is loose on the thong hole. That tube is only held in place by friction, so once the tight fit is disturbed then the end of the knife really doesn't have much to hold it together. I can feel it move when I squeeze it.
It's probably not a big deal, but it definitely has changed the feel of the knife. I think I'll fix it by buying some really long 2-56 screws and run them through the clip mounting holes into the corresponding holes on the opposite side. Or I suppose I could epoxy it.
Anyway, let this be a warning to you. Be careful if you decide to take your Manix 2 apart. That thong tube fitting won't take much misalignment.
