Pink Manix2 Dyed Purple
Hello all, I decided to dye my pink manix2 purple.
I chose purple because one that is pretty much all the supermarket had... two, I like purple...
Took off the scales, and dyed them using rit. I left the pot on a simmer for about 20 minutes. To be honest, I think I made them a little too dark, but thats ok.
Here are the pictures:
Please note that the pictures do not do the color justice.
With some other purple knives to gauge the "purpleness"
Thanks!
Nice work. Here's mine in dark brown:
Not the most accurate representation of the color but it's the best I can do. It's a little lighter and has a slight reddish tint in real life. What did you do to make the lanyard pipe fit again?
When I took it apart I pulled them off which took some effort.
When I put them back on I encountered some trouble again. I basically wiggled, and jiggled the scales back on.
There is just a hair and I mean hair of "scale play" near the lanyard hole. I was going to maybe try and glue the scale to the liner which just a simple dab of crazy glue near the lanyard hole.
What I did was to find a metal rod that fit the pipe (which is easy to do since the pipe is a standard size) and expanding it by rotating the rod in a circular motion while the scales were clamped to the liners. It got rid of the play but I'm guessing it's not nearly as tight as it was before.
