I've recently finished 5 handles. 3 Pakkawood on Green River blades and 2 stacked leather handles on Mora/Helle blades. On the last one (Helle), the blade slipped while I was compressing the leather causing the bolster to be out of kilter.
So, I'm going to practice pinning and soldering bolsters.
I am going to order a couple of Green River boning blades and brass bolsters with the correct notch. I have some Sta Brite solder and zinc chloride flux and a small butane torch.
I am really concerned with making sure the holes through the bolster line up. this involves drilling through the tempered blade. I've read horror stories about trying to drill through tempered steel. Do I need to use a carbide bit or are there less expensive alternatives? Likewise, is there a good substitute for a pin reamer?
I've read 3 different schools of thought on soldering, the first being don't do it use epoxy instead.http://www.bladeforums.com/forums/images/smilies/smile.gif
The second and most popular was to apply flux to the clean joint, heat and apply the solder to the joint, allow capillary action to draw the flux into the joint. Do I need to worry about corrosion if I use zinc chloride as the flux? Will a potato keep the end of the blade cool or should I get some heat paste? Or is there another alternative?
The third suggestion was to tin the blade and the bolster, attach them, then heat to get the solder in the joint to flow and bind. This makes sense to me but I'm not sure if this will result in a dry joint? Are there any problems that I am not seeing with this method?
Thanks in advance for any help and advice.
Bo Thomas,
Hobbyist
Bo Thomas,
Hobbyist
