I use T-88 slow cure structural epoxy. Structural epoxies are strong in themselves. Bonding epoxies only make a strong bond.
I will share another part of my book with you chaps. This trick is one I developed, and do not know of any other maker who uses it. If making knives in batches, it speeds things up as well as increases accuracy . It eliminates waste ,too.
The process I have developed is this:
Glue up one scale to the tang and let cure overnight. Use the lightest gripping clamps you can get. HF sells them for about $0.75 each...get a couple dozen. I clamp both ends and the middle, but the grip is just enough to squeeze out the excess epoxy.
Once cured, clean off the tang ( belt sander) and drill 1/8" holes through the center of the tang holes ( BTW, I drill the blade tang holes at 150% the shaft size of the bolt being used)
Glue up other scale.
Using the first drilled hole, drill through both scales with an 1/8" bit, then re-drill with a bit the size of the Corby shaft.
Place on the shoulder jig and drill for the Corby bolts:
The shoulder jig is just a block of 2X4 wood, a 1.5" long piece of round stock the size of the Corby shaft ( from an old drill bit), and one Corby bolt female side.
Place a blank block of wood in the Drill press vise to act as a backing block, and lock everything in place when drilling the handle out for the Corby bolts. Don't move the block or vise after drilling the handle out. When drilling the handles, set the quill stop tallow the bit to drill about 1" into the block.
When all the handles being done are drilled out for the shaft size, place the piece of round stock in the hole made in the block by the drill as it passed through the handle. ( see last paragraph for the handle shaping step to be done at this point)
Place the scale on this shaft hole size stud, and use the counterbore from the other side. Move the handle from hole to hole, boring all the seats on that side.
Remove the shaft hole size stud, and counterbore the block hole deep enough to insert the Corby female part and have the body stick out about 1/4".
Flip the handle over and place the bored side holes on the new stud. Counterbore the holes as before.
All this sounds complicated, but all it is is a way to always align the top and bottom of the hole. It doesn't matter if the scales are parallel or not. It will work with a tapered tang, odd or tapered shaped handles, antler, ivory, etc.
Once all the shoulder seats have been made, check the Corby bolts by dry fitting, and when all is right epoxy the bolts in place.
The advantage of gluing up the scales and then drilling the seats is that there is no issue of misalignment caused by any of a dozen variables in the scales and the tang.
First, when you glue up the handle scales, every space gets sealed and all is snug. There is no excess pressure to cause scale ends to lift up and make gaps where they were not before tightening the bolts down. You can use just enough clamp pressure to assure a thin and even glue line.
Second, once the epoxy is cured, you can cleaned up the scales on the grinder and inspect the tang/scale joint all around. If there is a problem, it only takes a knife blade and a mallet to split the scales off the tang, and fix the problem ( a little heat will help,too).
If all is well, drill the scales for the shaft size. It should be a good slip fit,not tight.
Then pre-shape the handle to remove about 80% of the excess wood.
Now, do the shoulder drilling as above. The pre-shaping before the drilling and adding the Corby bolts eliminates the scorching of the handle by all the rough grinding, and eliminates wasted Corby bolts when a handle flaw is discovered in shaping. The bolts don't get glued in until the handle is ready to finish. The bolt shoulder depth is easily controlled, as you will know how deep it needs to be once the handle is pre-shaped. The more wood under the shoulder, the stronger the mechanical bond.
So - strong epoxy + a strong fastener + installing in a strong way = a super strong handle.
