Pistol Cleaning
Sorry if this has been answered here before. The search function didn't reveal anything similar to me.
My local gun shop called me the other day to inform me that my new Stoeger Cougar is in. This will be my first pistol, so I'd appreciate a little input about maintenance.
I'm going to need some cleaning supplies. I already have Militec-1 for lubrication. I am a knifeknut:cool: . I assume I'm going to need a bore brush of some sort.
What I'm not sure about is what other solvents, wipes, or materials I should use. I assume the manual will cover this, but I'd like to have an idea before I take it to the range.
Further, is the rotating barrel different to clean than standard Browning tilt systems? I'd appreciate feedback from any other Cougar owners.
Otherwise, I'm looking forward to some fun time at the range in a couple days.(I'm busy with some young ladies until then, in case you all were wondering why I'm forgoing the immediate opportunity to test it out.)
First read the owners manual to learn how to field strip it and clean it.Rotating barrel designs have been around for ~ 100 years ! No difference in cleaning.Clean it regularly and don't forget to occasionally to remove and clean the firing pin and extractor ! Miltec will work fine .One of the nongun oils that works very well is Mobil 1 !! FBI found that out in tests.
I can't say enough god things about Hoppe's Elite solvent. I use it on all my rifles where carbon and metal fouling are a big cause for concern, and Hoppe's Elite just tears right through the stuff. I hear it's even good on plastic wadd residue in shotguns. I'd suggest getting a couple bronze brushes (not expensive) and either a brass jag or a patch loop of some sort.
The concept of "breaking in" in a new gun is controversial. There might be some merit to it with benchrest rifle barrels, but even there it is not certain if it helps at all.
I certainly have not done any breaking in with any of my handguns or rifles and they work just fine and are plenty accurate.
Just get a cleaning kit. If your store only has the ones for a rifle don't worry. The rods come in sections and you only have to use what you need. Besides all the different caliber brushes will come in handy for your next gun:D
if the pistol is for self defense i strongly reccomend 200 or 300 rounds be fired thru it to ensure proper functioning with the carry ammo and to let the thing break in.
i know some folks who buy a new gun, load it up, and carry it without ever firing it, not a good practice at all imho.
gives ya a reason to go shooting which is a good thing lol.
some manufacturers (kahr for 1) say to go thru 200 rounds before ever depending on the thing, and one of mine malfunctioned some for the 1st 20 rounds or so then cleared out and hasnt done it since, so some do require a little breaking in imho.
Hey Guys...
eojk...
Two Words for a cleaning kit..
Bore Snake !
Excellent piece of kit..
Usually I swipe through with it and the barell is clean....
ttyle
Eric
O/ST
"Break in" for a semiauto pistol has nothing to do with accuracy. It has to do with smoothing parts so the gun functions properly .SIFU1A has it right ! Carrying a gun without firing it is VERY foolish, carrying a gun without training is VERY foolish !!
Hey Guys...
eojk...
Bore Snake !
ttyle
Eric
O/ST
My first thought when I saw this thread was Bore Snake !.
IMO there is no better method to clean your pistol , or rifle. It is uber fast , does a great job and very compact. You will not need any brushes or rods with tips that can scratch or mar the inside of your barrel.
You may still need a small toothbrush style and maybe some q tips for touching up but otherwise the only two things I ever take with me to the range or the hills are a can of Breakfree CLP ( the best IMO) and my Boresnake.
Best of all when it gets too gunky or dirty just wash it by hand with soap and hot water and let dry , viola ! new snake !. :thumbup:
My Dad and Bro liked mine so much they bought their own. :)
I agree on the bore snake! I have one for my 12 ga and one that pulls double duty on my 357 magnums and my 9mms. That and Break Free and a brush or two is all you need.
I found out my local shop has Bore Snakes, so I'll grab one. I'm a little confused on the Break-Free though. I already have Militec-1, and the two products appear to have similar uses.
Can anyone clarify why I should look into some CLP Break-Free if I already have Militec-1?
Oh, and I definitely intend to run a couple hundred rounds through the Cougar to get acclimated to it and begin the "break-in" process.
Thanks for the help, all.:thumbup:
After reading about Miltec , hmm.
The whoile point of a Boresnake and BF CLP is lessening the componeents you need to keep your firearm in clean , working order.
With Miltec you still need some sort of a cleaner or solvent to clean your firearm.
With BF CLP you only need it , since it does all of the above , cleans lubes and protect , hence the CLP.
Not downplaying Miltec , if you like using it by all means continue doing so , you can use a boresnake with it i'm sure but you'll need to add a cleaner of some sort.
