Well thanks to Josh I have just finished the "rebuild" on my Buck/Strider full size spear point. Now the thing is I can't get the pivot adjusted correctly. I have taken the knife apart several times before with no undo grief as to getting it back together with the pivot adjusted correctly.
The thing that is happening now is that the blade is rubbing the liner lock. Seems no matter which way I adjust it. I thought before I took it apart that I had the left side pivot screw torqued down to bottom and then the right side pivot screw I used as the adjustment screw to center the blade and such. Anyhow getting frustrated with it and am asking guidance in this matter before I smash the s.o.b. with a hammer! Anywho any and all info is appreciated. Keepem sharp
