I got a new large 21 from ES today. The knife was made in 7/12. The blade was stiff so I took it apart to lube it.
I've tried to put the blade back in the knife many times. The pivot bushing moves to the side with the small washer Every
time I try to put the knife back together. The small washer isn't against the inside of the scale, the pivot is moving just enough
to keep the washer out of place. The pivot bushing is moving the thickness of the small washer.
I'm holding the lockbar out so it's not in the way. I called CRK, they couldn't tell me what I'm doing wrong.
I've had the same problem before, I got lucky and the pivot didn't move for some reason and the blade went in the
knife correctly.
I'm using CRK grease to keep the washers on the blade.
A little help .....very frustrated!
knife correctly.
