ToyKnife
- Nov 19, 2006
Basically, when it comes to frame/liner lock folding knives you have two options when it comes to how the blade is attached and operates/pivots. Option A, is a pivot with a separate bushing and screw/bolt. Option B, is the all-in-one pivot screw.
Option A - allows the user to tighten down all the screws evenly which means you get a consistent fit/lock up each time. But you cant adjust the pivot to be tighter on the blade which affects how much pressure is needed to move the blade and will aid in fixing blade play. In addition, generally, one doesnt have to continually adjust the pivot with this system (coming from Sebenza owner). All you have to do is tighten and use, the screw doesnt loosen/back out, etc.
Option B - allows infinite adjustment; loose, tight and everything in between. The upside is you can custom tailor the feel of the blade movement. It is generally cheaper to build and has fewer parts to deal with. The downside is the user has to continue to adjust the pivot for a consistent feel and blade play. Now the only experience I have is from Benchmade. BM is no custom or high production. With the BMs I have noticed that the screw/pivot bolt likes a particular setting. Tighten the screw and it backs out to that setting or leave it at that setting and it loosens more. You need to play a little dance with the pressure once a month (depending on how much you use your knife).
On with the questions.
Which system do you prefer? Have you had the same experience?
Is there a difference with better built folders regarding the pivot screw/bolt option? Think customs, Strider, Hinderer, Emerson, etc. Do they have the constant adjustment problems?
What maker/manufacturer uses a pivot bushing system for their folders besides CRK?
