- Aug 4, 2010
Hey guys I was wondering if some of you have this same problem, I just bought of the exchange a regular with a carbon fiber scale it came with the original titanium scales as well. The knife is perfect when in original form perfect centering and rock solid but when I try to install the carbon fiber the same way, I can't even move the blade. I need to loosen the pivot and actually more so the blade stop screw almost until its free spinning in order to be able to open and close the blade. now what Im thinking is that the carbon fiber is softer and the stop sleeve and pivot bearing is setting into the carbon fiber a little leaving less room for the washers, which also causes the blade to be off center. anyway it seems like I know what the problem is but I was just wondering if anyone else has had this issue, and if they had a way to deal with it other than leaving the screws loose?
