I did a test piece the other day to practice peening a slipjoint pivot pin. I used a piece of paper micarta and drilled the hole for the washer with a 1/4" end mill. I put a drop of superglue in the hole and inserted a small piece of 416 stainless rod, then drilled a hole offset by about 1mm from the center of the rod and reamed it with a #41 reamer. Before peening the 3/32" pin, I used a small burr to taper the hole on either side. The good news is that the pin blended into the washer, the bad news is that I have a gap. The picture makes it look really big, but I honestly did not see the gap until I took the picture and zoomed in.
What is the best way to avoid this gap? Can I peen the washer to fill the gap before peening the pin?
