Planer Blades
A friend just gave me some planer blades. I understand from another forum that most of these are D2. Would they have markings indicating this and if not how do I tell what they are. I seem to have an endless source for them. Also, do they have to be heated to soften them before grinding them into knives. Thanks for the help.
Marcel
Dude, I just went through that exact song and dance myself. I sent a one by one inch chunk of it to a guy off of the knife-list and he sent me back a chemical analysis of the steel. Turns out it's not an exact match for any of the usual tool steels, the closest was A2 with a little extra chromium. The anneal cycle for A2 is quite difficult and requires a programmable heat treat oven with temp controls, stainless foil to keep it from scaling away to nothing, and about 18 hours of oven time.
Most planer blades I've run across are not marked with steel type or even manufacturer. If (big if) you can verify with the people you're getting them from who they order them from, you might be able to get a steel composition from the manufacturer, but there is no guarentee it's the same from one lot to the next.
If you have a pretty good idea that some of the blades you are getting are from the same batch, you could get an analysis done and send them out to Paul or Rob for annealing, then they would grind up quite nicely, but....as with most salvage steel, it's a crapshoot.
One last note, as far as I know, none of the air hardening or stainless steels can be annealed just by heating to critical and slow cooling. YMMY
Good Luck
James
Those who are willing to trade freedom for security deserve neither, and in the end, seldom retain them!
most of the planner blades of 5/32 are d2 or will respond to d2 heat treating methods the only other culpert is m2 witch is to hard to heat treat in a regular oven it needs a comercial job aneal d2 in oven to critial and let oven cool over nite
All that is not Given Is Lost
I got a couple with the manufacturer stamp on them that I verified with them as being D2. I don't worry about annealing them, but they are a PAIN to forge. Does anyone know what companies use D2 rather than M2 or A2? It would be good to watch for.
Oz
Now, what other news did I have? Oh yes, IT'S A GIRL!!!
See her and my latest blades @
http://www.freespeech.org/oz/
I bought a couple planer blades from the same source that Madpoet used to use. They were annealed, but they were damn near impossible to use files on, and they were a real b!tch to grind on a 30 and 60 bench grinder wheel, too. I recently made a blade from L-6 and the difference was incredible.
My Knife & Sheath Pages:
http://www.geocities.com/CollegePark/Lab/1298/frames.html
Palmer College of Chiropractic
Sheath Makers Referral Directory
agocs_s@dd.palmer.edu
Madpoet (Mel Sorg, Jr.) Tribute page:
http://www.geocities.com/CollegePark/Lab/1298/madpoet/main.html
